Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
Does the top gear float on the jackshaft? I have a bit of a gap between the 36mm nut and washer.
theCATman
- Feb 19, 2007
- WI
- Yamaha
No. It should be tight. The nut won't go any farther??
Fast Lane
- Feb 6, 2020
- Winnipeg
- Winnipeg
No thats it. If I adjust the jackshaft so the washer touches the top gear, then the woodruff key for the brake rotor wont fit.
theCATman
- Feb 19, 2007
- WI
- Yamaha
And that's how it was when you pulled it apart?? No other washers??
RobX-1
- Coldwater, OH
Happen to have mine apart and the washer and nut are tight against the top gear:
theCATman
- Feb 19, 2007
- WI
- Yamaha
I just had the chaincase apart on my 08 Vector and I'm 99% positive the top gear wasn't floating.
theCATman
- Feb 19, 2007
- WI
- Yamaha
I think you're missing a spacer/washer behind the top gear.
Fast Lane
- Feb 6, 2020
- Winnipeg
- Winnipeg
Im missing a spacer between the bearing and top gear ffs. No idea where it went too. I hope Yamaha can ship parts ASAP!!!
RAMSOMAIR
Likely back ordered until March lol.
Fast Lane
- Feb 6, 2020
- Winnipeg
- Winnipeg
Its being rush shipped. I wasn't sure which collar so I ordered both lol. Im positive its the one right behind the top gear. Add some more random parts to the parts bucket!!! lol
Fast Lane
- Feb 6, 2020
- Winnipeg
- Winnipeg
Anyone know much about top gears? I have a 21 tooth gear. I heard the vector has a 22. An Apex has a 24. Could the 973cc pull the Nytro up to a faster top speed with a 24 tooth top gear?
theCATman
- Feb 19, 2007
- WI
- Yamaha
It'll pull it, you'll lose bottom end power. And you'll need a longer chain also to jump 2 teeth.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
A stock Vector is over geared, and the RS Nytro was under geared. If you look in the TY tech pages you can find the factory gearing specs, pick a ratio in the middle that’s gonna work with your stock chain and enjoy better fuel mileage with a little more top end. Note: you may need to tweak your clutching a little bit.
