hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Has anyone considered welding a bung on the back side of the chain to put a drain plug on the chaincase? I'm going to look into this and was wandering if anyone already did. If it works out I'm thinking I could have guys send me their case to have the drain plug installed. I'm sure I'm not the only one wishing for a simple drain plug!
This would be the cats #*$&@ to be able to retro a plug into as an after market part. You could drill it out and have a drains with seals on both sides that could be lock in with shallow lock nuts but have the center removable.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
just thinking out loud but wondering if there is enough material in the chain case to just use a self tapping auto drain plug instead of the bong or a drain plug from any other Yamaha sled and just tap the hole
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I like the way you guys are thinking come up with something that works please.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
You do know the chaincase is made of magnesium ?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
The oil tank resi is def mg as it is cast into the piece. I actually think the case components are aluminum.
Anyone have any damaged inner chain case sections laying around?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I was thinking of just tapping the case with 1/8 inch pipe thread plug...........just thinking out loud but wondering if there is enough material in the chain case to just use a self tapping auto drain plug instead of the bong or a drain plug from any other Yamaha sled and just tap the hole
canadianhunter
Couple other things : There use to be an oil pan drain plug repair that was a rubber thing that you stretched with a rod, pushed it though the hole and when you removed rod it swelled on both sides the hole. I know, a poor explanation.
Also a tubeless tire valve stem except would be a small drain hole.
