phazerkid
thanks for all the replies guys.But i have one more question.
What are you using for chaincase oil?
4strokelover87
Amsoil 2000!!!! Great stuff!!
Len Todd
I use Yamaha's chain case oil. But, ...
Anyway, sounds like you got this one solved. Good luck!
any synthetic gear oil will do. i am running royal purple 75w140 in mine.
rbailey3711
- Feb 27, 2008
- Crystal Lake, IL & White Pine, MI
- '16 SR Viper
Hey did you check the other end of the driveshaft bearing while you were working on it?
I've got 6500 miles on my '04 Warrior and the bearing went on the speedo end, took out the sensor ..... sealed bearing.
Found in forum and yamaha that you should replace both ends ... plan to do the chaincase end this spring.
I had the same luck Monday night on my 05 RX1
vtdownhiller
RedRX1 said:I had the same luck Monday night on my 05 RX1
Tuesday afternoon for me...must be an epidemic
Len Todd
All you got to do is repack the bearing at the end-of-season and mid-season and you should be good to go for many moons!Key words, end-of-season: You need to make sure you get all the water out before letting is sit for 7 months.
