Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2008 Vector GT 40th Anniversary
2014 Viper LTX
Why does a sled with reverse take less chaincase oil then a sled without reverse? Also ,I put 85-140W gear oil in my 08 Vector. Manual recommends 75W GL3 .This stuff is GL4. I assume theres little difference.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I've always wondered the same thing. I just fill it to the line in between the two and I have never had a problem.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
On the belt guard it says 8.5 oz. Doesn't matter if it is an ER or if it doesn't have reverse.
Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2014 Viper LTX
I was told by a sled mechanic ,its because of the extra gear in the chaincase taking up more room. Kind of like adding ice cubes to a glass. It takes less liquid to fill it.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
exactly so it is 8.5 oz either way but with the extra gear it fills it further.
Pstn head
So what would happen if it was overfilled ? specifically on a viper, mine is almost up to the top of the sight glass. Around 1/16" of an inch from the top of the sight glass.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
if it builds pressure it can blow a seal but there is allot of room for expansion so would need to be way over filled.
Metallicat
I called Port Yamaha today, they said the Yamaha chaincase oil bottles are 8oz. and to use that amount in all models, standard and reverse (Viper is different). 8.5 oz. is close enough. If you fill it to the "rev" line on the stick that is only like 3oz. which is really a small amount.
ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
Ive been running 16oz in my viper without issue. 85 90 syn gear lube
Metallicat
Vipers are different, I was posting for Apex and Vectors. 16oz. is a lot!
ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
viper also calls for 8 oz
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
3 oz.???!!! A typo Mike?
8 oz. get's me to the REV line on both of my Vector's. 14 Vector Owners Manual says .26 Imperial qt.
Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2014 Viper LTX
hmmmmm. i'm still not sure now on this topic. I filled it to the rev. line which is considerably less then 8oz.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Actually it calls for 12 oz (or 355ml)
