DeepFrz
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
DeepFrz said:After putting on my new track I've started putting the chaincase back together but ran into a problem with the whole reverse deal. Is this on right?
And after taking my skid plate off, I found this piece. Any ideas where it came from?
The reverse looks and sounds right to me.
That piece looks like a bushing.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Could it be the CAP to your sub frame
radianguy
- Jan 1, 2007
X2APEX 06 said:Could it be the CAP to your sub frame
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
radianguy said:X2APEX 06 said:Could it be the CAP to your sub frame
X3. Mine fall out and end up in the bottom all the time.
DeepFrz
I reconnected everything and fired it up. The sled is in gear, but I cant get the reverse link to reach the shifter handle. Any ideas?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Reverse
Pull off your chain case cover again. You have the reverse fork misaligned. You need to drop it on the top of the gear groove as you push the cover back on.DeepFrz said:I reconnected everything and fired it up. The sled is in gear, but I cant get the reverse link to reach the shifter handle. Any ideas?
