Chaincase with reverse oil capacity??
Mighty
Grand Ledge Michigan USA!
22 Mach Z
23 Sidewinder SRX
Does anyone know the chaincase w/reverse fluid capacity in onces?
PS: on a rage
I checked my service manual and it only lists one chaincase capacity: "0.25 L (.022 Imp qt, 0.26 US qt)"
While it shows the two different full marks on the dipstick, it doesn't list different capacities for models with or without reverse. Maybe they take the same amount and the larger case for the reverse models results in the lower level on the dipstick. They don't list the capacity in ounces but .26 quart is about 8 ounces for most liquids.
Capacity for chaincase oil
Lot of discussion on this before. I believe the spec was 8.5 oz.
I'm not sure on how many ounces I had put in, but in my ER, I just have the level midway between the upper mark on the REVERSE side and the lower mark for the STD side of the dipstick.
