Chassis setup for speed runs
justin1620
Rainy Lake, Ontario
Canada
Sidewinder
WEBSITE
www.rustymyers.com
Has anyone found out what works best for chassis setups for 1000ft speed runs? 2018 sidewinder ltx with 270 tune and 22 tooth top gear....chisels/triggers mixed. So far I have less preload front ski shock springs, tightened limiter strap, and loosened off preload off both rear shocks.,.clickers on 1, removed coupler bar, torsion spring on lightest setting? Any suggestions?
The lower you get the back end better you will do top end. Sucking limiter in 4 holes was 3-5mph on Viper.
