hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
New to me sidewinder and it doesn’t have a dipstick to check oil like my viper did. How is the oil level checked on these ?
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Clear fuel line on back of tank by a bunch of wires.
hognit09
- Mar 7, 2010
- beaver dam, wi.
I saw that, but how do you know what’s low or full ?
mainedrummer
There a sticker on the case directly under the tube indicating Min. and Max. level.
hognit09
- Mar 7, 2010
- beaver dam, wi.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I believe you check oil just after warm-up with engine off. As oil will drain back to tank and appear to be slightly overfull, after a bit. Hope that makes sense.
stgdz
- Mar 27, 2021
- Buffalo MN
Two redlines
You want the oil level to be just above the min line when cold and not above the max line when hot.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
some oils airate ... or foam more than others, i was using REDLINE 0w40 with cat filter and lust switched to AMSOIL signature 0w30 with a K&N filter the redline would foam up over full line but soo far the amsoil is just below the full line after long run. same 3 us quarts. (946mlx3)
fourload
What can happen if the oil is above the full line when hot?
Turboflash
- Mar 18, 2019
- Southern MN
Depends on how much over full it is. Since this is a dry sump engine, too much oil in remote oil tank will not cause there to be too much oil in the engine UNLESS there is so much that it cannot drain (actually it's pumped by oil pump) back into tank. There are baffles inside the oil tank with holes, etc to prevent oil from aerating and sloshing around. If there the tank is too full, some of these may not work right.What can happen if the oil is above the full line when hot?
Too full probably causes additional pressure on ROV.
If the tank is just slightly over full, there really shouldn't be any negative effects.
Guys have said there will be more oil vapor in system (vent hose from valve cover) with tank overfull. I've not experienced that.
