snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Right. That's why I posted here as this is an audience I would trust. Hasn't been a lot of chatter on this forum on it, but it looks to be because they are not failing. Great news.
FYI - I updated the title so it better reflects the intent of the post.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Running the 02 module since the beginning of this season and have had zero issues with it.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Ran into a guy yesterday on a red winder with red undergrowth lights in Autrain. He said his sd-24 doesn't come up on dash when key is turned on. He said he was working with Dave to get it fixed.
I bet he's on this forum but I didnt catch his name.
Fasttrax
My sensor lasted one trip..100 miles. Blew a belt WOT and noticed code after that. New sensor..700 miles later still good.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
My O2 sensor failed before my sled hit the snow. What are the Dos and Dont's when it comes to longevity of these O2 sensors? My buddy has had 2 fail in 100 miles. What are we doing wrong?
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
How do you have it installed in the down pipe to muffler ?My O2 sensor failed before my sled hit the snow. What are the Dos and Dont's when it comes to longevity of these O2 sensors? My buddy has had 2 fail in 100 miles. What are we doing wrong?
Also are you using any fuel additives or engine oil with high ZDDP?
DMCTurbo
- Nov 12, 2005
No fuel additives.How do you have it installed in the down pipe to muffler ?
Also are you using any fuel additives?
no1b4me
- Dec 31, 2016
That is a temperature issue, very close to turbo outlet, the recommended distance is 24 inches from sensor OEM's, however not all applications allow this spec.... Your right on the bell of the downpipe.... And EGT's are high.... The only other possible mount is to remount on a 45*so that the sensing tip is facing more downwardNo fuel additives.
DMCTurbo
- Nov 12, 2005
That's how the bung comes on the TD 3" intimidator exhaust.That is a temperature issue, very close to turbo outlet, the recommended distance is 24 inches from sensor OEM's, however not all applications allow this spec.... Your right on the bell of the downpipe.... And EGT's are high.... The only other possible mount is to remount on a 45*so that the sensing tip is facing more downward
no1b4me
- Dec 31, 2016
Rich fuel conditions generate extreme high temperatures, these O2 's really don't like temperatures above 850*F for long periods of time.... Need to look at your fueling, what are AFR' s like?That's how the bung comes on the TD 3" intimidator exhaust.
Are you running a FPR?
DMCTurbo
- Nov 12, 2005
I have closed loop. Sensor failed before I hit the snow.Rich fuel conditions generate extreme high temperatures, these O2 's really don't like temperatures above 850*F for long periods of time.... Need to look at your fueling, what are AFR' s like?
DMCTurbo
- Nov 12, 2005
No anti-lag Bob.Have you been using your anti lag ? Anti Lag can be hard on O2 sensors
Are you sure its the actual O2 sensor and not the module?
no1b4me
- Dec 31, 2016
There are 2 LEDs on the module.... What are they signalingI have closed loop. Sensor failed before I hit the snow.
no1b4me
- Dec 31, 2016
DMCTurbo
- Nov 12, 2005
Normal
- 6K
