YamaMikeRTX
Grimm
Just put them back on and go. As long as you put the shims in the same places, you'll be alright.
YamaMikeRTX
thanks, I think I remember howmany went where!
ROCKRTX
Don't forget you have a X inside the cover and another one inside the primary clutch,you must align them or you will have a vibration.The secondary is balance too,if you take the 2 sheave apart make sure too mark them before take apart.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
good luck
YamaMikeRTX
Ididn't mark the secondary
baggs66
their will be drill marks on each sheeve from balanceing line these up across from each other
YamaMikeRTX
thanks! that helps put alot I haven't put it back together yet cause I've been worried!
