apex yooper
How can the chain be looser on a reverse, when you adjust it, per manual, exactly the same?
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
Cool, another clutch kit thread and this one started by the boss. :roll:
While the efforts we've seen the aftermarket suppliers put into developing these kits is commendable, it's certainly refreshing to see the stock setup as being pretty decent right out of the box.
I for one remember the days where something, anything seemed to be better than what we were given as stock. I suspect the aftermarket suppliers had quite a bit to do with pushing Yamaha to provide decent stock clutching.
Thanks guys
Thanks guys
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
We have already established that it is not. The slop is were the driven gear and reverse gear mesh together. They are side by side. The main 'driven' gear runs on a smooth shaft and transfers the movement through the reverse gear (they are side by side) which is attached to the driveshaft. That is why the secondary rocks back and forth.apex yooper said:How can the chain be looser on a reverse, when you adjust it, per manual, exactly the same?
When you run in reverse, the reverse gear is moved away from the driven gear and it is spun by a reverse idler, just above it.
Wait till you open it up sometime to see!!
- Sauk Prairie, WI
- www.ty4stroke.com
SledderSteve said:Cool, another clutch kit thread and this one started by the boss. :roll:
Thanks guys![]()
This is by far the best Yamaha has ever clutched a sled...BBY
Turk
Tech Advisor
Matt; I am with you on this one. I gained a bit with just a helix change but when you hit 300+ miles the stock clutching is pretty impressive!
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
The clutching this year was designed to reach full RPM's within a few hundred miles. Earlier years the clutching was designed to reach full RPM's well over 1,000 miles. Yamaha finally realized that we race these sleds form the get go and were getting a bad rap by the poor results. Only drawback to doing it the way they are now is that we eventually will have to adjust clutching to bring the RPM's back down. For instance, my Attak with 300 miles is hitting 11,000 RPM's. Neither my RX-1 or Warrior would go above 9,200-9,500 forcing me to buy Heavy Hitters. Hind site being 20-20 I would have taken Turks advice and removed the rivet in the tips of the clutch weights and saved some coin
yrunderattak
can anyone tell me what the helix angle is on a stock attak
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Turk said:Matt; I am with you on this one. I gained a bit with just a helix change but when you hit 300+ miles the stock clutching is pretty impressive!
Hey Turk, I am not having much luck either !
