Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Anyone come across a list of instructions on how to pull apart both the primary and secondary clutches to give them a proper cleaning.
I have looked in the FAQ's showing the steps to upgrade to an Ulmer kit buts that's it.
Any special tools
Lubricating parts on reassembly - if any
Possible wear items.
Never had them apart before, and wanted to do this during the summer.
Mark
Any special tools
Mark
yamariv
Exactly the same topic I wanted to post! Need to do a complete cleaning this summer too!
Kirkdking
I'm pulling mine apart the week ill take some pics and some wording make up a slide show.
yamariv
Kirkdking said:I'm pulling mine apart the week ill take some pics and some wording make up a slide show.
Sweet, thanks!
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
Look for a post from me "Mills" about a free download of the Nytro service manual, everything you need will be in n thee manual.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Depending on your mileage another possible wear item are the metal bushings in the primary and secondary. I am planning on doing mine before next season.
Dodge Ram
<http://www.marclatulippe.com/ManuelShopMotoneige/Yamaha/Yamaha%202008-2011%20FX%20Nytro.pdf>
Here it is.
Here it is.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Check your ramps, bushings, springs, rollers look over the sheaves for cracks then clean. DO NOT use lube on any part of the clutch DO NOT use any break or carb cleaner on the clutch. Wash with HOT soap water use dawn dish soap and then blow dry.
yamariv
Hey Kirkdking,
Any luck with your clutch cleaning tutorial? Looking forward to it!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
I would like to know - can the whole clutch be serviced and cleaned without pulling it off the drive shaft of the engine??
MS
MS
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Sevey said:I would like to know - can the whole clutch be serviced and cleaned without pulling it off the drive shaft of the engine??
MS
No
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
So just undoing the bolts that hold the face of the clutch and cleaning on the inside is not good enough?
MS
MS
Dr. FeeLGooD
I use brake cleaner and just do as Sevey has asked. Seems to work for me but I could be wrong. I havent had any issues that I can see but I am the first to admit I am a backyard hack.
- 12K
