PigeonLake
Does anyone know of a solution to this clutch rattle? Do any of the aftermarket clutch kits quiet down these noisy clutches. Not so bad wearing my BRP Modulaire, but in my CKX Titan backcountry helmet style the noise is almost unbearably aggravating at trail speed. My buddy has a 2014 Viper and his clutches are dead quiet
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
It's the "snakes rattle" - enjoy it!
Dinner
I haven't really looked at the primary on the sidewinder. However for the vipers, you can purchase shims for the roller bolts to quiet them down.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
It's the "snakes rattle" and it's almost impossible to get rid of the rattle without killing the snake...enjoy it!
Pries
- Dec 6, 2015
- Calgary
- 2007 RS Venture
2008 Nytro MTX
The rattle comes from the tiny bit ofPlay between the stub shaft blinds and the splines on the end of the crankshaft. The fix is to Paul the stub shaft and use the green bearing retainer Loctite. The stub shaft will still be able to be pulled later if need be.
There are various threads the deal with this
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I call my SW "my little diesel! It is loud. Is this common among SW?
Pstn head
What the guy with the two guns said !It's the "snakes rattle" and it's almost impossible to get rid of the rattle without killing the snake...enjoy it!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Finished up maintenance on my sidewinder. I ran the motor a bit to get oil circulating and check for leaks. I didn’t have the primary on the crank and I was just amazed how smooth this motor sounds. No more diesel. It’s just amazing how bad the primary rattles. You guys with aftermarket primaries do they rattle like the oem ones?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
TAPP, CVTech PB80, and Arctic Cat Adapt clutches are quiet(er).
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Here ya go, this will fix ya up lolFinished up maintenance on my sidewinder. I ran the motor a bit to get oil circulating and check for leaks. I didn’t have the primary on the crank and I was just amazed how smooth this motor sounds. No more diesel. It’s just amazing how bad the primary rattles. You guys with aftermarket primaries do they rattle like the oem ones?
Knockout kit
Has anybody used this yet, and who makes it? https://turbodynamics.mybigcommerce.com/arctic-cat-yam-knock-out-kit/ It says its supposed to help with harmonics and quite a bit cheaper than other vibration elimination kits (Hurricane one). Just wondering if it actually works and what the...
ty4stroke.com
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
If you don't want to spring for a TAPP, the new ADAPT clutch has been a good unit in the field.
- 7K
