HABS 1
- Oct 22, 2015
- corunna,ontario
was wondering the best way to remove and install clutch weight rivits, have herd tap lightly and peen with hammer only on rivit not weight, if any one knows or a video link would be cool! also herd 1 gram brings rpm down 100 rpm, true?and if so i assume 1 gram off all 3 weights lowers rpm 100 not 300 rpm correct?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
drill the head off, punch it out, new one peen over with a hammer.
X2
HABS 1
- Oct 22, 2015
- corunna,ontario
did that! actually easier said than done with out touching weight! i will peen over with hammer but have herd the weight will break easier than expected!hammer and punch sounds so rough, iv been handing like fine china!! any input on rpm changes as per gram?
I actually use a weight tool to remove the rivets that support the weight and allows the rivets to drop thru. They are stronger then you think.
HABS 1
- Oct 22, 2015
- corunna,ontario
ok thanks , ill look for tool,just dint want to break these weights, its a dalton kit and was expensive! i see now he has adjustable ones with washers etc! oh well, any input on rpm change
HABS 1
- Oct 22, 2015
- corunna,ontario
found pic of tool on internet, its perfect! i need one but cant find forsale, where u get yours?found one listing for 32 bucks used but it expired! might just make one!
HABS 1
- Oct 22, 2015
- corunna,ontario
ended up laying on flat part of vise and just peening with hammer , worked good , thanks for the help, also found the weight rivit weight chart in tech section! awsome chart! i orderrd those part numbers scaled them when i got em and the chart is bang on!! thanks again! no input on weight to rpm change though?
