clutch weights
snolover
just open the clutch of my new rtx 06 and
i found 81.8 grams at my surprise . last year the RX1 was 74. grams same spring as last year y.s.y. So wath you think of the top speed guys
The only way to tell is wide open throttle rpm,s. The RX-1 weight was pretty flat allowing for more mass so the new weight at 82 grams must be flat as a board. The one thing I have found is that as long as peak rpm,s are hit & the belt ain,t slipping you won,t gain a lot on a regular trail driven sled.
