DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm slipping the belt on topend. How do I get more bite on top end? Very close to my goal of 130 in 1320 on pump gas. I think if I can solve this slip it'll put me over the top. Running an 8JP.
Thanks in advance.
Thanks in advance.
snowdust
You probably want to put your current setup so others can help. That said I see it in the other post and I'm guessing others smarter than me are going to say to wrap the secondary more. I ran my B/O at 80 and now at 90 it is pulling better. No gun to prove it other than racing other sleds.
DMCTurbo
- Nov 12, 2005
Ya I'm kinda figuring that. I can't load the tips of the DTYA2s any more.
DTYA2s @ 85.29 grams
Dalton black bronze
Dalton black orange at 70 gen1
35 helix
8jp
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
rearrange the weight towards tip if you have adjustable weights
DMCTurbo
- Nov 12, 2005
The weights are near full and it's all towards the tip.
Maybe you need the drill press scale Knapp-style.
What about going back to the Yamaha secondary spring.
Or XS825
Or XS825
DMCTurbo
- Nov 12, 2005
I have tried the stock yellow spring and went backwards (with 8jp). I picked up an XS825 and will break it in easy this weekend. I realize I'll need to go down weight. Do you think the xs will help with the slip up top?Maybe you need the drill press scale Knapp-style.
Or XS825
They seem to grip well. I just swapped to one on a stock 18 and it brought the revs down a little.I have tried the stock yellow spring and went backwards (with 8jp). I picked up an XS825 and will break it in easy this weekend. I realize I'll need to go down weight. Do you think the xs will help with the slip up top?
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
I think the xs will help!
Wrap the spring to a higher setting.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Don’t me to hack this thread but I been running 8jp belt going to try the xs825. I am wrapped 3/3 with reverse helix and orange sec spring. I do hit the rev limiter on occasion. With the XS belt should I leave it at 3/3 ?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Thanks in advance.
Have you taken apart the secondary to look at the inside of it? You are not slipping on the topped in the primary, it's the secondary you are worried about. Let's see the pictures of that.
DMCTurbo
- Nov 12, 2005
Ok will do that later. Do the marks on the top of the primary sheave not indicate slippage?Have you taken apart the secondary to look at the inside of it? You are not slipping on the topped in the primary, it's the secondary you are worried about. Let's see the pictures of that.
KnappAttack
- Feb 19, 2004
- Welch MN
No, If it was slipping it would be polished up or blackened. The belt will never slip at the top of the primary clutch. You could see some blackening up there but more from letting off and belt transfer from the secondary releasing from the belt. All you are seeing at the top of that clutch is where the cord of the belts are running at full shift which is typical.
DMCTurbo
- Nov 12, 2005
Ok Mike here's my sheaves untouched after probably 15 1/4 mile passes.No, If it was slipping it would be polished up or blackened. The belt will never slip at the top of the primary clutch. You could see some blackening up there but more from letting off and belt transfer from the secondary releasing from the belt. All you are seeing at the top of that clutch is where the cord of the belts are running at full shift which is typical.
- 7K
