Clutching question ?
swampcat
N. E. Wi.
2020 S W LTX-GT
What will happen to the engagement if someone mixes up a special BLACK MAGIC combo of.... Thunder Venom kit, with a Barn of Parts soft touch spring ? Will the engagement end up in the basement at 1200 rpm ? Or will it be the Super ultimate KILLER Clutch set up of all time ? Discuss.
It depends on what the rates are on both springs. The stock primary spring is used in the Thunder Products Big Venom kit. The soft touch I do not know the rates of that spring.
The Thunder Products kit will engage very low the way it is. If you change rates and not change the weights it will either over rev or not rev to where you want it.
