GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I heard White Pink White was a good OEM replacement for soft start with same finish as stock:
" Using any yamaha spring with an initial preload of 30kg will give you a smooth engagement between 2800 and 3000RPM.
But if you want to have the same finish rate than your stock spring then use the white-pink-white spring #90501-583L5-00."
https://ty4stroke.com/threads/soft-start-yamaha-primary-spring.151716/#post-1410096
McLovin
- Jan 30, 2017
- Manitoba
- 1997 Mountain Max 700 144 1.5
Thanks a lot for the answers guys! Really appreciated. Part numbers and everything. Too bad I received two conflicting answers though haha. Can anybody else weigh in as to which Yamaha spring? Orange pink orange? Or white pink white? Has anybody actually used these? Does it change anything that mine is a 2016 MTX 141SE?
Thanks again for the help.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Try smaller rollers for smoother engagement
McLovin
- Jan 30, 2017
- Manitoba
Thanks, but am interested in trying the spring first. Sounds like very good results.Try smaller rollers for smoother engagement
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Ok. But another benefit of the smaller roller is that it will keep the clutching off the rev limiter on initial hit. Some more info to consider.
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I agree with stain. Smaller rollers will also help with lower engagement and they grip the belt harder. But are more money than a spring. Start with spring then buy rollers.
PAvector
- Feb 24, 2007
- Pennsylvania
- 2014 Yamaha SR Viper
I’m using a White Pink White, I like the smooth lower engagement and very close finish force as BSB.Thanks a lot for the answers guys! Really appreciated. Part numbers and everything. Too bad I received two conflicting answers though haha. Can anybody else weigh in as to which Yamaha spring? Orange pink orange? Or white pink white? Has anybody actually used these? Does it change anything that mine is a 2016 MTX 141SE?
McLovin
- Jan 30, 2017
- Manitoba
Thanks a lot guys, really appreciate the help. I will try white pink white as well, it's numbers are closer to BSB here too:
https://totallyamaha.com/snowmobiles/aaTECH/drivespecs/primary_springs.htm
I will see how much I like it with the different spring, and then think about rollers.
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
I just installed the BOP spring and it works great. $35 usd and $9 shipping.Thanks a lot guys, really appreciate the help. I will try white pink white as well, it's numbers are closer to BSB here too:
McLovin
- Jan 30, 2017
- Manitoba
Well I installed the white pink white. Was an improvement...but I didn't originally have a blue silver blue in there. Apparently my 2016 MTX 141 came with this green green green from the factory? Is the white pink white the proper replacement for this green green green I pulled out? The white pink white seemed to max out at about 8500 RPM.
Thanks for any knowledge.
PAvector
- Feb 24, 2007
- Pennsylvania
Looks like you should try orange pink orange. GGG has a higher finish force than WPW.Well I installed the white pink white. Was an improvement...but I didn't originally have a blue silver blue in there. Apparently my 2016 MTX 141 came with this green green green from the factory? Is the white pink white the proper replacement for this green green green I pulled out? The white pink white seemed to max out at about 8500 RPM.
McLovin
- Jan 30, 2017
- Manitoba
Thanks! Are you sure? What about pink pink pink? It has closest total force to the green green green.Looks like you should try orange pink orange. GGG has a higher finish force than WPW.
Thanks for the assistance here.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Just get the BOP one. I have them on both of my Vipers. No loss of top end and no driving through the back of the truck when loading the trailer.
McLovin
- Jan 30, 2017
- Manitoba
I would consider that, but my MTX 141 is apparently different. It came with green green green, not BSB...so I am thinking soft start might not be the proper replacement. Can anybody help me decipher this chart for best lower engagement replacement for green green green? Thanks.
