Last year I installed a Team Industries secondary. Had a stock track and 192 studs, no other modifications. Had the HH's in the box but never got them on because of no snow. This set up was 5-6 sleds faster then a stock rx-1 with same amount of studs. Would come out of the hole with or ahead of a stock zr9 and then he'd pull me 2 sleds in the mid-range. Needless to say I was pretty happy with the overall performace especially since the HH's were not yet installed. Now...the stock track is history and I've installed the rip saw with 120 Golddiggers down the middle, 3-2-3 pattern. My questions is how will this 1.25 track effect the clutching over the junk that was on there last year, will I need to change gearing, helix, a different set up with the HH's??? I realize that until it snows and we get some testing done we really won't know, but I wondering what you clutching gurus are thinking. I ride mostly groomed trails and lakes. Thanks!!
Turk
Tech Advisor
When using a weight with adjustable screws or bolts you just adjust the weight for the added load or mass. You can just clutch for the larger track. Usually just lightening the tip will get ya close.
