2007 Phazer ; Fresh 91 octane gas with some octane boost just in case . Sled runs fine ! Can the sensor go bad ? Is it possible to check it ? Is there a way to reset code on info pod ? I don't have a manual . Thanks .
It's not knocking. It's telling you there's a problem with the sensor or the wiring for it. Haven't heard of these failing before so I'd first check the wiring before buying a new sensor.
