GT03235
Just been playing with my handwarmers now i have a code 84 and 81 flashing?
GT03235
My right hand warmer is toast i removed the grip and the filament is shot, is the error code because of this? Can i connect the 2 wires together to delete this code? i am so sick of all these problems lol
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
TORS. You may have moved your throttle when working on the grip.
GT03235
so whats the cure?
stephenpen
I had code 84 come up yesterday after adjusting my riser. It was my throttle cable pulled to tight. I soon as I loosened the cable it went away. Not sure on code 81.
GT03235
ok got the tors system sorted disconnected the right grip and both codes now gone.......... so i see the rsi heaters have 3 wires not 2 like the yam any idea's?
mytro
GT03235 said:ok got the tors system sorted disconnected the right grip and both codes now gone.......... so i see the rsi heaters have 3 wires not 2 like the yam any idea's?
Usually what gets the elements is movement, I put my RSI's on and wrapped them with Electrical tape before putting grips back on.. Keeps them from moving. Wire Red and Blue together..
