SLED RUNS GOOD TILL WARNING LIGHT COMES ON ,ENGINE LITE AND CODE 84 LIGHT, THEN ITS LIKE YOU SHUT OFF THE THROTTLE, ANYONE KNOW THE REASONS FOR THIS? THIS HAPPENS DURING FULL THROTTLE PASS, AFTER ABOUT 7-800 ' RUN
the code comes on after full throttle runs because there is a problem with the TORS. you may have a kink in your throttle line. i had a similar problem and it went away after i remove the airbox and made sure all the lines were ran correctly
