CODES 13 & 14
..SNAKEBIT..
NE Iowa
is there a diagnostic chart for these codes?
both show cyl #1
intake pressure sensor
all I was able to check tonite was the hose is connected
13 says a short or open circuit for the #1 pressure sensor so I would suspect a problem on the circuit and 14 is just a result of 13. Either the sensor is bad or the wiring. Try swapping the plugs on the two sensors. If the code changes to a 25, then it's the sensor. If it stays 13, then it's the wiring.
I basically use the same method with coils on my truck. Please report back what you find. Would be good to know what might have failed.
ok when I start it, will the ecm read the sensor right away or will it have to warm up?.
I switch the wire harness and it still showed 13 & 14
so its in the harness or ecm?
any test I can do to the harness?
I would suspect the wiring before anything with the ECU (although I have just been through a complete failure of one myself). Grab a copy of the repair manual and check the wiring diagrams for wire colours and start tracing the wiring. Check the connector first since it is handled on a regular basis whenever we take the airbox off.
Mine did the same thing and it was the hoses connected to the bottom of sensors. One was broke of and one was just off
Will it switch sensor codes right at start up or does it have to run or warm to a certain temp before it starts to read the sensors?? only ran it for 5 secs, showing same codes???
If it was a problem with the sensor, then yes, the codes should have changed right away since there are no "stored" codes like in cars. That's why I would suspect the wiring.
