Compression Test Question
Smokey
Winnipeg
I am planning to do a compression test on my 04 RX1. I am assuming it is done when the motor is hot. Also what should the compression be ????
400 RPM...I assume that is what the starter turns the motor at....Do you run the motor first to warm it up before doing the test...
Jim I have a brand new gauge if you want to use it.
Hold the throttle slides open when running the test to get the correct reading, it reads higher with slides open cause more air enter the engine......
