coolant air bleed
backroads
McKinleyville, CA
Sled is 2009 Yam Viking Pro. Had right side tipover & lost fair amount of antifreeze out reserve bottle overflow. Sled would not restart & had to walk out. Pulled sled out and loaded. Will start at home, but has tendency to overheat easily (warning light on dash). Want to make sure all air is bled from system, but in spite of service manual, cannot find bleed screw. Can anyone help point out the exact location? Thanks
The bleeder bolt is located in the storage box right behind the latch. It is covered by a rubber plug.
Thanks so much for the info on the storage box. Just went out to look and no rubber plug near the latch. I made a mistake on the year; it is 2008. May be there are slight differences between years. I'll keep looking, but any new info is helpful.
I finally found the air bleed with a great deal of thanks to those who took the time to lead me to it. Picture shows latch in storage box and rubber plug displaced to access bleeder bolt. Thanks to everyone.
