viperwings
- Oct 28, 2007
- Michigan
- Attack GT & Nytro XTX
- SE Michigan
Could I get some help on if there is any instructions for bleeding the coolant on my sled. I the tubing that is held into the engine with a brazed bracket failed and the O-ring was not being held in place and the pressure forced coolant out. I am replacing the tube (should have never have broke) and want to be sure to bleed the lines correctly.
