cr8zybaby
- Dec 21, 2017
- 2007 attak gt
07 attak,is the titanium exhaust gonna be ok with the copper donuts? Everything bolted nicely back together and there's no loose exhaust clamps etc.
Just looking to see if it's gonna last. Either way I'm gonna SEND IT
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you will be fine the pipes crack most time because the stock donuts wear out and cause clamps to become loose the copper last forever. as long as the clamps went on tight those joints wont give you anymore grief. there are other areas that can crack and fail I would add support to the next joint in the system like the 08 and up sleds have so it don't fail there next.
cr8zybaby
- Dec 21, 2017
- 2007 attak gt
Thankyou siryou will be fine the pipes crack most time because the stock donuts wear out and cause clamps to become loose the copper last forever. as long as the clamps went on tight those joints wont give you anymore grief. there are other areas that can crack and fail I would add support to the next joint in the system like the 08 and up sleds have so it don't fail there next.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
My titainium cracked and warped all over. So I replaced with stainless pipes. No more issues and I used stock donuts and ground the clamps a bit so they tighten more
RobX-1
- Coldwater, OH
Did the same thing on my 08 as I don't have plans to get rid of it anytime soon so replaced titainium headers with SS and added the copper donuts.
