Could I run
Sledguy89
Grand Rapids MI
Hey guys, as I'm waiting to order my clutch kit a pcV I was wondering if I could run my sled a couple of passes in local grass drags to feel it out. I have the full exhaust an k an n's. My question is will it hurt anything by doing this. Thanks for any input in advance....
Brad
Shouldn't hurt anything, but with filters and an exhaust, it'll run lean and probably feel like it has less performance than it did stock. And when I say "shouldn't", I mean cause you are only going 500', and that shouldn't be long enough to burn a valve or piston.
Brad
No, have fun...
Thanks for the input guys, I know what happens running bikes lean jus was in sure if the nytros still supplied jus enough to not burn it up
