Sledguy89
Hey guys, as I'm waiting to order my clutch kit a pcV I was wondering if I could run my sled a couple of passes in local grass drags to feel it out. I have the full exhaust an k an n's. My question is will it hurt anything by doing this. Thanks for any input in advance....
Brad
Brad
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
Shouldn't hurt anything, but with filters and an exhaust, it'll run lean and probably feel like it has less performance than it did stock. And when I say "shouldn't", I mean cause you are only going 500', and that shouldn't be long enough to burn a valve or piston.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Sledguy89 said:Hey guys, as I'm waiting to order my clutch kit a pcV I was wondering if I could run my sled a couple of passes in local grass drags to feel it out. I have the full exhaust an k an n's. My question is will it hurt anything by doing this. Thanks for any input in advance....
Brad
No, have fun...
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Should be fine
Sledguy89
Thanks for the input guys, I know what happens running bikes lean jus was in sure if the nytros still supplied jus enough to not burn it up
- 13K
