Cpr Simons roll call
RED
alberta
Wonder how many of you guys have one. Looking to bs about stuff about them. Thanks ;)!
cpr clutching
anyone running 51 degree helix with silver spring with cpr front mount if so what setting are you running I had it on 70 and ate the bottom of the secondary shieves in about 15 miles any body got any thoughts on the problem I had a 45 degree in befor and no problems.
I found quickly you gotta run a ton of secondary side pressure with that Turbo. That means a dual angle or lower single angle helix & a silver secondary at 100-110 twist or white at 80-90 twist. Anything else & the belt slips huge in the secondary.
I have an 05 RX-1 ER. CPR installed the kit. Will probably get to play with my unsuspecting friends between Xmas and new years !
Just finished mine up. 03 shorty, micro belmont 4 post clutch, can't wait to get out. Looking for a zr skid.
Use the White secondary spring 3-1 or 6-2. It works alot better than the silver with the turbo. I use the Dalton 58-44 or 61-46 helix. The 58-44 is the best overall. I have heavy hitters and really load them up. With a stock primary I think i had them about 74 grams and about 58 in the quad clutch. Go right to the 25 top gear also. You will lose nothing on the bottom. I'l have to check the primary spring, I thinl it was the green silver green or aybe the pink silver pink. Not much belt slippage and it pulls like a b......
05 RX1er very nice kit and clutch kit easy install. And man, this sled is fun.
5 miles on mine so far in the orchard, pulls hard. Need to get some miles on set-up before I go to Quebec (St Zenon) for New Years. Have HH setup which is very close for now. Need to put more twist on Secondary (white @ 60) cause even in 300ft I can see rpm's starting to drop. Had coolant leaks and oil leaks (my stupidity) which reduced the fun factor dramatically.
Don't feel bad we have all been there! ;)!
Had my CPR Turbo on the 04-Warrior sense the spring time and have about 150mi on the tar this past summer... How about this on a summer night, "...yea, I'll be doing 135~137mph on my trail sled tonight, What are you doing again...?" Was my favorate question to my co-workers... he,he... LaLaLa
Just finished up at a couple back yard grass drags and that was a blast...
Next is: Install Expert-X, make some clutching adjustments for the winter season and we are off... Waaahoooo!!!
:Rockon:
--Buster696--
