tonykof
ok so I'm a moron...I was check the wrong side of the plug. When I check the resistance of the 2 wire plug (black plug) going to the stator with my dial set at 2000k I get a reading of 130
I would go ahead and change the pickup coil, or entire stator as some suppested - its up to you.
This was fairly common on 07 Apex.
tonykof
Yeah that's kind of what I was thinking, Thanks for you time trying to help.
tonykof
Looks like it was the pickup, I tested the stator and it was good. But since I had a parts RX1 I just used the whole assemble (stator and pickup) fired right up! Thanks again for your help guys! Tony
Aspx
- Jan 8, 2022
- Altona Manitoba
- Yamaha Apex gt 1000 2007
I have the same problem just order a stator from Kimbex I really hope that will be the fix
