leepster
Has anyone bought one of these crank sensors from the guys on ebay? I so how did you guys install it and check the gap between the sensor and the stator rotor? Thanks.
duste
- Nov 25, 2008
- New Glasgow, N.S. Canada
- 2007 Attak
From what guys do you mean? I bought a OEM one from ebay and all was fine but I have been warned to stay away from RM stator out of Quebec.
I bought one from rm on ebay which he is out of Vermont, the tolerance was so far off it hit the crank on the first revolution and broke. He was a really nice guy and refunded my money in full.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
ebay
Got one from RM on ebay also still have it it the box would not work probably had the same problem as ssp the tolerance was probably off also. Just didn't go with it. Got one from Yamaha and it was going again.
apex55
This is the one I bought. Had to splice the plug and file back the holes to move it closer, just as the directions say.
http://www.regulatorrectifier.com/catal ... ickup-coil
Glacierrr
- Feb 19, 2013
Very simple to check.... I just used tape to measure distance of oem one before you take it out. I measured from tip of sensor to stator.. I bought stator and sensor from rm stator in Quebec and the only issue was I had to file or open the bolt holes on sensor a little to get it approx 3/4 of a millimeter closer to stator. Been working fine for approx 600miles.
To give you full story I just installed it normal first time and still no start! So I did it all over installing oem sensor just to measure and noted new one was off by above amount! Tiny bit of filing reinstalled and good to go...
leepster
Thanks guys, i am trying the crank sensor from rm, got one for 39 bucks, got it all tore apart, measured and ready for the new part, which was supposed to be here today, but the USPS shitheads didn't get it here in time. Now I have to borrow my neighbors skidoo 500 2up to ride this weekend. DAMN
leepster
Just an update for you guys. Got a crank sensor from RM stator. installed it and sled starts and runs great. Crank sensor looked exactly like the on I took out and the gap was right one. I guess we'll see how long it lasts but so far the sled is back up and running again for about 50 bucks asa opposed to 300-400 for a stator.
apex55
Good to hear. Thanks for following upleepster said:Just an update for you guys. Got a crank sensor from RM stator. installed it and sled starts and runs great. Crank sensor looked exactly like the on I took out and the gap was right one. I guess we'll see how long it lasts but so far the sled is back up and running again for about 50 bucks asa opposed to 300-400 for a stator.
How many miles did you guys have when the pickup coil failed? going to replace mine to be safe ,dont want it to go when im out having fun miles away...
apex55
How many miles did you guys have when the pickup coil failed? going to replace mine to be safe ,dont want it to go when im out having fun miles away...[/QUOTE
Around 8500 miles..How many miles did you guys have when the pickup coil failed? going to replace mine to be safe ,dont want it to go when im out having fun miles away...
Thanks. It seems like any where from 7500mi - 11000mi they fail..
Awesome news... great job. Maybe post up the part number. You have any pics?Just an update for you guys. Got a crank sensor from RM stator. installed it and sled starts and runs great. Crank sensor looked exactly like the on I took out and the gap was right one. I guess we'll see how long it lasts but so far the sled is back up and running again for about 50 bucks asa opposed to 300-400 for a stator.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
That's NOT the one I got from them. Had to take the sled in and have the dealer install an OEM (indexed) sensor to get it running right.Just an update for you guys. Got a crank sensor from RM stator. installed it and sled starts and runs great. Crank sensor looked exactly like the on I took out and the gap was right one. I guess we'll see how long it lasts but so far the sled is back up and running again for about 50 bucks asa opposed to 300-400 for a stator.
apex55
I did the RM and put 2500 miles last year no problem. I did have to file out the bracket to get the gap correct though. Mine said to do that in the directions.
