Cutting track windows
Round Track Hole pics
I believe the request for pics was for the round holes.
Seen a pic of a Doo in the latest issue of SnoGoer that had the round holes. They said the reason for "portiing" this 3rd window was for more snow onto the heat exchanger?
I cut out my track windows today. It took a little over an hour with a sharp utility knife. I used the kind with the snap-off blades and snapped off a section every 4-5 windows. The fiberglass cords definitely dull the blade...
The pic below shows the weight of the 32 pieces that are removed from a 121" track: 6.3oz. Probably insignificant, but that's the data for those who need to know...
This is by far the best thread I've found regarding the subject. Here's some additional info I pulled up in my research.
Here's what Tracks USA has to say from their FAQ's:
What about a "3rd-window-closed" snowmobile track?
"The 3rd-window-closed design was initially introduced about 1997 in a 1.250 track for snowcross racing as a method to reduce weight and retain snow in the skid frame for lubrication. A 121" track of the 3rd-window-closed design weighs about 2 pounds less than a fully clipped track. I have never seen a 3rd-window-closed snowmobile track show any signs of wear in the unclipped rubber area.
Observing the OEMs, all four manufacturers are now using 3rd-window-closed designs as original equipment on most models. A few fully clipped snowmobile tracks can be found on performance snowmobile models able to achieve relatively high top speeds. I am sure their testing has shown that in most conditions, the 3rd-window-closed design performs the best, is lighter in weight and costs less to produce."
I disagree with their statement about never seeing any wear in the unclipped area. Check out the pic of the RipSaw on my Nytro.
Here's some additional info.
http://www.camoplast.com/tracks/snowmobile_tracks/clipping.php
I'm planning to cut my track windows.
