See n blue
Does anyone's tuning software allow you to record/data log a run? I've seen the live data on Gap's software which is really cool but wasn't able to replay anything. Maybe we were doing something wrong??
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Bottom right of screen Logs button (next to info). Your flasher has to have the datalogger option.
actionjack
- Apr 9, 2005
See n blue
Thanks, will double check to see if that option is there. For some reason I don't think it is..Bottom right of screen Logs button (next to info). Your flasher has to have the datalogger option.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
It's an added cost to have datalogging capabilities.
See n blue
Thanks, it's a pretty important feature imo.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
The tuner may not have activated it if you paid for it they can activate it like sending a tune
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
That's debatable. For the average trail rider, I would say it's useless. If you like to race a lot it might have some value. I have it, and too be honest, might have wasted 250 bucks on it. It's like another 500 to get a/f ratios data logged. And now we've discovered that you can run 16 psi on 87 octane pretty much. And the stock sled can't physically run over 17 psi without modifying a few things. Just use the live data to see if you're pulling the proper boost, and should be good to go.
See n blue
Very true however when testing different maps it's nice to gauge what this machine is doing. I find being important info for clutching etc. You're right though, the average trail rider should be able to trust the tune they have and not worry about anything else. I was merely asking about data logging because it can be a helpful feature for many that like to play!That's debatable. For the average trail rider, I would say it's useless. If you like to race a lot it might have some value. I have it, and too be honest, might have wasted 250 bucks on it. It's like another 500 to get a/f ratios data logged. And now we've discovered that you can run 16 psi on 87 octane pretty much. And the stock sled can't physically run over 17 psi without modifying a few things. Just use the live data to see if you're pulling the proper boost, and should be good to go.
- 44K
