1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
What do you get for top end with tuned winder and 1.75" track?
123mph on speedometer on the trail.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
FYI
Running these large lug, unstudded tracks on trails should be illegal. It ruins the trails blowing snow off the corners way into the woods. A much safer alternative is a 1.25”~ 1.5” track with studs to prevent excessive track spin on the trail. If your off trail some, then the 1.5 will get it done. If your getting stuck with a 1.5” off trail buy another machine suited for that purpose.
I’ve seen it first hand so it’s not worth arguing. Stop ruining the trails riding big lug, unstudied tracks on the trail system.
This doesn’t go for you 1nc, you ride in the UP where you get so much snow it doesn’t matter. I’m talking trails in wisconsin and areas that don’t get +200” a year. Down here they are snowblowers and 5 sleds like yours can easily throw off every inch of snow into the woods.
Thanks CM
Thanks CM
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
A big X2..FYI
Thanks CM
I see it all the time in Ontario and Quebec, last year in Quebec I was leading our group when we caught up to 2 sidewinder xtx’s going about 60 kph and they were destroying the trail beyond belief. I actually had to drop back because of the snow chunks coming off there sleds, looked like a slinger truck throwing ice/snow chunks around.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Look what showed up the other day!
Look how wide the windows are.
Clipped every window with side clip every third window.
It doesn't have a direction marked on it but I would assume the cupped lungs would be on the forward side.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
That's odd that your new track doesn't have and rotational direction arrows on it.
Check the first page of this thread. There's a few pictures of the Storm 150 track on my sled that should help you out.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I found the direction arrow.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
For you tuned guys who have ran both the 1.25” Ripsaw II track and the 150 Storm, what are your thoughts? Which do you prefer? Why?
Put an ice storm on a friends 129. Lugs are coming off. Have had no issues with the rip 2/ice attack. Some guys are noticing a slight vibration with the storm also.
Red Rocket
- Jan 5, 2015
- Ontario, Canada
- 2023 Yamaha Sidewinder LTX DX
I have been running the Storm 1.5 2 ply for a couple thousand km's now fully studded 4 per row down the middle and am happy with its traction over the stock track.
I have lost one lug but I think that was due to some rather large sharp large exposed rocks early in the season.
I have Dupont sliders as well and they seem to be holding up fine. I haven't noticed very much increase over the stock track in vibration and with the shorter side lugs it still seems to corner well. I don't think this track will last as long as a Rip saw 2 but it does perform better traction wise.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
If you are running a stock sled I believe the Storm is a great option. I liked it on my stock Sidewinder tune. If you tune it over 200 hp, like I did, Then it does not take the abuse. At least mine did not......
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I am running 1.625 studs on a storm 150.
144 studs down the middle.
With track adjusted with 1/2" sag with off ground the studs are starting to scratch the tunnel and luvers. Not running tunnel protectors over the coolant tubes. I do have tunnel protectors over the rear heat exchanger and no issues there.
Time to install the full length STM tunnel protectors. Track looks like new after one season on it.
How tight are you guys running this track?
Turboflash
- Mar 18, 2019
- Southern MN
Per TD 998 Performance Guide:
(https://turbodynamics.mybigcommerce.com/td-performance-guide-for-998-turbo-snowmobiles/)
- Make sure you have a tight track (must not hang at all when lifted off ground, must be hard to push off the front bogey wheel). It is highly preferable to have a 4 wheel kit upgrade to maintain reliable track tension especially when running high power and or fast speed. Running a loose track will rob lots of top speed (as track baloons from centrifugal forces). Also loose track can cause ratchening of track drivers which will damage them and or the track. Radar running require a VERY tight track as high speed cause expansion.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Any new reviews of the ICE STORM from anyone
Have had trouble with lugs flying off at high speeds on two different sleds, good snow conditions.Any new reviews of the ICE STORM from anyone
Wouldn't reccomend.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
the ice storm is a single ply track and should never used on a sidewinder or t cat, they balloon sooo much like the cobra did, the 2 ply is the way to go and add your triggers or TiTanium studs.
- 15K
