RXW10
Found a DC outlet for plugging in your electric sheild in the 07 accessories catalog. Says that it's for RS models....any reason it can't be put on the RX models?
Part # 8ET-W8192-00-KT
RXW10
RXW10
Oak Hill
It will work just fine!
RXW10
I couldn't figure out why it wouldn't, but thought I would check with the experts. Thanks OakHill.
Oak Hill
I don't think I am an expert, but thank you! Glad I could help.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
The only issue you will have when trying to use that kit is that your RX model doesn't have the pigtail to plug it into installed from the factory on the sled (the RS models and phazers do). So if you buy the kit you will need to run wiring to the area you install it in to hook it up.
Len Todd
I just ran a length of two wires (Two stripped off a 4 wire trailer cable) down to the terminals on the jumper cables. Wrapped the wires around the terminals several times and slipped the plastic cover back over the ends to hold things in place. Then, I put a fuse in the hot wire right at the connection to the Jumper Cables. Routed the cable up to the handlebar and out from under the Pad Cover right next to the Parking Brake. On that end of the wire, I installed a female RCA plug, that I got from Radio Shack. Wire tied the cable under the hood to keep it from bouncing around. Got severl K miles w/o problems. Ole' Army saying is applicable: KISS
NY_Nytro
Yeah the RS sleds are prewired for it as the connector is right there behind the gas tank cover, you'll need to add the wiring to a RX sled. Just a little extra work.
