pat the rat
- Mar 13, 2006
,i drained my battery twice this summer by leaving the key on,i charged it fully both times but it seemed like it was not keeping its charge,today it let me stranded,i was in the bush at our moose hunt camp,i shut the bike off to take a break and have lunch,15 min later,no starting,it was ticking like a dead battery,no pull cord so i walked 5 miles back to my truck,im writing this just to find out if there's a way to start it without a battery,what kind of back up would work
mudduck
- Jun 19, 2009
did you check charging circuit? why don't you buy a new batt?
get one of those jump start packs bring that with you.
pat the rat
- Mar 13, 2006
i know i have to get a new battery,but i thought maybe its the charging system that's not working right,those bikes need 12 volt steady cuz of the efi,if battery is weak,the engine light comes on and if you stop,it wont idle,it will just quit,got a code 46 today wich is a power supply problem
Camo7
- Jun 30, 2007
- Calmar, Alberta
- Calmar, Alberta
The bike will turn over the engine in high range if you tow it. Only works if you have someone to pull you or a steep hill to go down. The one way clutch that makes the engine braking work so well will also spin the engine over. Don't know what would happen if the battery is really dead though, you need enough power to run the fuel pump and EFI.
pat the rat
- Mar 13, 2006
talked to my dealer today and he said some 07 and early 08's had some stator failure and yamaha covered it out of warranty,he will test it tomorrow and i will find out
pat the rat
- Mar 13, 2006
well,my stator is shot,common problem on some 07's,dealer told me 99%sure yamaha's gonna cover it,even the battery might be covered,i think its good that they stand behind their products like this
Muskoka Man
Pat
Good to see Yami will cover your issues
, Ill be in The Gowganda area on Oct 2,3,4 for a bike run before the hunting starts , Sounds like your town will be packed for the plowing match , Maybe we can get together this winter for a sled tour
MM
, Ill be in The Gowganda area on Oct 2,3,4 for a bike run before the hunting starts , Sounds like your town will be packed for the plowing match , Maybe we can get together this winter for a sled tour MM
pat the rat
- Mar 13, 2006
plowing match is the only words we are hearing right now,it is busy right now with the crews working on site,i have a variety store in town and its a little nerveracking to get prepared for this much people,as for sledding,would be fun to go for a rip this winter,will keep in touch
