ok guys, i had a chance to test some wires, here is what i found, there is a white plug that plugs into starter relay, it was three wires, a red/green, red/white, blue/white, without touching the key the red/green has power, other two don't, when I turn key to first position(prime) all have power, when I turn key to start position, blue/white loses power, other two stay powered, of course the main terminal attached to battery has power, other terminal going to starter does not, that sound correct? Am I safe to assume starter relay fried?
