jp111
My dealer called me the other day with some tips that he has been getting from the dealers up in Canada along from yamaha.
The main one he told me was that if you turn the key on to start the sled, then turn it off momentarily without letting the instrument cluster power down fully that it will make it extremely difficult to fire.
He also mentioned the battery deal as well. He said that if they are not fully charged form the get go that due to the long battery cables and voltage drop it can kick a code and make the sled not want to start.
Just thought I would throw that info out there.
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
jp111, Your dealer is a salesman, not a tech guy, if he thinks the length of the battery cables in a sled will cause to much voltage drop. He,s feeding you a bucket of donkey dust.
I can understand the problem, if the battery is low, but the length of cables is really stretching the truth. Might be worth wiring up a battery tender to the battery, and keep it plugged in while the sled is not being used.
I do that with my Apex, and my truck. A topped up battery is a good thing to have.
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
Yamadog said:darv said:Well my buddy has a new viper won't start.
Get a new buddy![]()
Mine starts everytime!!!![]()
LMAO that's awesome! Mine starts every time too. But sometimes starts hard.
I have other things that start hard.... well not so hard bt I have blue pills for that you don't see me crying about it here though
YamahaTim
- Sep 21, 2013
- Farmington, MN
Well...I don't need them yet...lol but I do want some more hp!
Ahhh blue pills in the tank?
YamahaTim
- Sep 21, 2013
- Farmington, MN
Could work...I'll check what it out.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
fitch catalyst lol
LM7800
- Dec 4, 2011
- ohio
- 2016 viper ltx LE sold
had this issue tonight. took sled out for 3mi got back in shop, it sat 30min, went to start and just crank and crank. cycle key on, off, on, off. Finally I played with what would be TORS on a real Yamaha and it took off. hope this doesn't happen on trail.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
Well buddy still having problems with his viper took 6 try's with letting set also 1hour in between the first try and the last when it started call dealer in Bemidgi Mn dealer he told him they are having problems with the vipers an the cats doing the same thing as his no fix.
rxwhopper
Mine has this issue also when it is warm. Gave me a code also and oil light wouldn't shut off. I cycled key and after a few try's it lit. Getting to not being very fond of this.
