darv
- Aug 9, 2005
- 08 Apex 40th LTX
Well my buddy has a new viper won't start.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
battery
Nytro40th
- Sep 19, 2007
need more info
DeerHuntr
Kill switch? The cluster comes on with the key even with the switch off. Start simple and go from there....
darv
- Aug 9, 2005
- 08 Apex 40th LTX
It turns over but will not run just when you turn key off,
pjabas
- Feb 11, 2013
- Montgomery ,MN
- 14 sr viper xtx se. 153" track turbo
Give it just a touch of throttle.. maybe the tss is f ed up
09nytro
Sounds like the battery !
You could also check the kill switch , but I'm thinking the battery !
loudelectronics
Turn the key on and off a few times to prime the fuel pump.
Lots of peoples friends have problems with there sleds. I have a buddy with an XM 800 etec and just blew the motor in first 20 miles. Friend with a RMK took drive shaft out on first climb of the day...
HYFLYR
Make sure the battery is fully charged. These new sleds are very finicky as to battery strength. Why? Im not really sure but it seems to be the case and Yamaha is aware of it.
nbsledder
I just went through this with my 2012 nitro...turn over was normal but would not start,checked battery said it was weak put new battery in and it took right off.
- Apr 14, 2003
- Hessel, Michigan
BETHEVIPER
sounds like battery. when it is cranking, if it drops the voltage to the coil packs below 10volts, they wont fire. One bad cell will get it there.
Blu2U2
By chance was the OEM tether put on the sled? My Viper had issues with this so the dealer disconnected it and it starts fine now.
2BLUE4U
This has happened to my viper many times already...I dont think its the battery. It typicallyhappens after the sled is warm and you shut it off and then try to start it shortly after. I cycle the fuel pump twice and then it pops right off. I think its a mapping issue
Yamadog
darv said:Well my buddy has a new viper won't start.
Get a new buddy
Mine starts everytime!!!
