MarkRTX
What will it doe going from 60 to 70 with a white secondary spring?
- Sauk Prairie, WI
- www.ty4stroke.com
It will slow your shift. I wouldnt do that on a stock sled. you will rev very rapidly and loose top end performance. Leave it at 60. Also it will coil bind anything past 60 degrees.
MarkRTX
Thanks for the info. Now I switched from a silver to a white spring and it feels snappier throughout plus revs to 10800 or so where the silver would start at 10000 or so and slowly climb to 10500 which is best?
- Sauk Prairie, WI
- www.ty4stroke.com
Run the white, but remember not to twist it past 60 degrees.
- 14K
