2008 Nytro RTX
My sled has a slight push in the corners, inside ski lift and it bucks going over big moguls sometimes. What adjustments should I make to help me out? I am going on a big ride this weekend and would like to get it out before then. Please help
zeke66
Rebound bucking? Where you have your clickers at?
Try using this:
Or use this chart made by TY4 members, it helped me out a lot.
http://www.ty4stroke.com/viewtopic.php?t=62502
Try using this:
unpride
try going faster! Slow down your rebound and take a few psi out of your floats maybe even tighten up your front limiter strap a hole
2008 Nytro RTX
Yea,I cant view that last one for some reason =^(
zeke66
Mine is doing the same thing yours is, in corners. Over studder bumps, its good right now. As I recall, my rebounds are at 5 or 6 and I weigh @210 no gear.
I do think I may end up tightening the front strap a hole. Going to see how it goes tomorrow because it was only lifting on turns with loose snow.
2008 Nytro RTX
I have my shocks at 50 psi so that should help with the cornering,Now I am going to try and get rid of the buck I get
nytro addict
I have clickers but my buddy runs the fox shocks and he has 60 psi in his shocks. He also went a hole down on the limiter straps. If stock skis switch the spacers around and it will widen the stance. That helps alot in the turns.
yamahahaha
take the screw out farther in the rear shock, and adjust the triangle to soft, take 5/10psi out of the front schocks
2008 Nytro RTX
I already have them at 50 PSI. What you mean triangle?yamahahaha said:take the screw out farther in the rear shock, and adjust the triangle to soft, take 5/10psi out of the front schocks
nytro addict
I believe by triangle he i talking about the torsion spring block. There are three settings : H-hard, M-medium, S-soft.
