quebec#1
Was having a great day saturday and took a short cut to get home decided to stop and take on the view and size up the trail situation to go home.
Noticed prestone coolant leaking under sled . Took side panel off and found a punctured rad from the reverse arm since the rad broke all clips that was attached to the machine the rad and reverse arm had a battle and the reverse arm won !
Did manage to walk about 6k to a road and make it home. The next day a buddy drove me with his machine to my machine we manage to get her back to the road and on to my trailer. I used a type of putty to cover the hole and fill her up with prestone just to get her back to the trailer.
Is this a common thing ?
Please see pic !
Please see pic !
teamyamaha
How many miles on the sled?
Snowmobileaddict
Could have happened to me...
I noticed that my tabs were cracked and got my rad. and had it replaced under YES coverage.
I caught this small problem before it grew into a big one.
quebec#1
9500 miles all four tabs are broken.teamyamaha said:How many miles on the sled?
aceltx09
Wow,never seen that before. I will check our sleds. These radiator and heat exchanger problems really suck. All it takes is one rock to hit a pick in the right spot and have it come loose into heat exchanger. Scary when you think about how far we go and how scarce those parts are to get quickly. Makes a really good day go bad fast!!!!!! I'm gonna keep some of that puddy in the sled from now on,I have heard of people on here using it with success.
Budweiser
I think its pretty common. I'm gonna guess that's an 06. They did beef up the tabs on the later years. They are broke on my 06 but I rigged something up to hold it tight. JB weld and ingenuity!! Has worked so far.
Kaz
After seeing this happen on here a couple of years ago, I tye wrapped the cramp out of the rad to prevent this should it ever happen on my 07.
In either 08/09 Yamaha beefed up the rad mounts.
Kaz
Kaz
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Budweiser said:I think its pretty common. I'm gonna guess that's an 06. They did beef up the tabs on the later years. They are broke on my 06 but I rigged something up to hold it tight. JB weld and ingenuity!! Has worked so far.
Ever 06 I've seen has that happen. The new ones are nicer.
sherlock29
my 08 rad mounts broke..... at least one has... so not sure if they are actually stronger... my 07 rad is perfect.
08 has 10300
08 has 10300
quebec#1
Any stronger updated versions ?
sherlock29
make a stroger one?!! somebody with some aluminum welding should be able to wip something up..
quebec#1
I see the 2009 has a different part #
teamyamaha
Just looked at my 09, it looks much beefier then the the one in the pictures!
quebec#1
Just ordered a new one .teamyamaha said:Just looked at my 09, it looks much beefier then the the one in the pictures!
The part # is 8fp-12461-00-00 for 2006 to 2008 the 2009 # is 8FR-12461-00-00
I was worried that the 2009 might be a bit different so i played it safe and ordered the original part #
Do you have a pic of your rad on the 2009 ?
quebec#1
Looked at the micro fiche and the 2009 does look beefier !
Now wish i would have ordered the 2009 part !
