Dip stick to check oil
kampkoleviper
Pennsylvania
2006 Apex GT
Where is the dip stick to check the oil level at on a 2003 rx-1 I found the chian case stick but not the engine oil Thanks
There is a plug to remove the two wires, in case you were wondering. This is a picture of my Nytro but should help. Unplug the connector on the tank and unscrew the stick. Gibby is correct on the check procedure.
Here are the pages from the 2003 RX-1 Service Manual for checking/changing oil:
Click thumbnails for larger images.
