CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I figured I would post it here because it can apply to the winder or viper. I have an irritating line going through the left side of the screen on my viper, basically cuts off half of my temperature readout. My question is, if I bought a new display gauge would the dealer or anyone be able to pre-program the kilometres on to the new gauge? I’ll get a picture tomorrow morning...
G.I. Joe
- Jan 3, 2017
- Elmira MI
- 2017 viper 153 mtx
I believe that is saved in the cpu. No programming necessary
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
so everything should come back? Hrs? Trip? ODO?
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Odometer and hours should. Trip probably won't
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Mileage I believe is stored in the gauge cluster, hours are stored in the ECU. So if you buy a new gauge, it will show 0 mileage, but will show the correct amount of hours.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
This is what I was afraid of hearing, do you know if they could possibly be programmed?Mileage I believe is stored in the gauge cluster, hours are stored in the ECU. So if you buy a new gauge, it will show 0 mileage, but will show the correct amount of hours.
- Apr 17, 2003
- Menno, SD
- Menno, SD
There is not a way to program it that I'm aware of.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Ok thank you!There is not a way to program it that I'm aware of.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
SRXspec is correct. I had a gauge warrantied at 5300 miles. The new one read 0 when I picked it up. The hour display is correct.
I took a picture of the mileage before the exchange so I could relay this to the next owner.
