I just bought an 11 se and I question if the floats are an upgrade over coil overs.. More specifically is the rear megafloat a good ride? I'm 185lbs any thoughts?
Q. Arrius
- Feb 6, 2015
- Indiana, (central)
- '17 Sidewinder LTX LE (red)
'12 Apex SE (black)
'12 Arctic Cat F800 snopro (129, orange)
'15 SRX 120 (blue)
''15 S.Doo Renegade XRS (Ronald McDonald colors)
I have a '12 SE, and it came with the same MegaFloat....and for lighter riders like myself as well, it was basically a death wagon. I'm 185 lb and to find the compilation of air pressure to work was impossible. The sled would basically and literally shoot from one side of the trail to the other, always for no reason.
And before anyone chimes in and tells you that you just don't have it dialed in, and all the other bs....it's about the weight of the rider. The Apex with the mega handles fine for bigger guys.
Second: if you stud your track, and the mega fails....what then? You rip your exchangers up.
Here's my solution:
Call HyGear and see what they can replace it with. I do not believe they are messing with trying to correct the shock itself. I have a Ohlin with the electronics ripped out, with their spring kit, and valved to my weight.
Add studs and tunnel protectors, switch skis to Curves with 6" slim jims. Add HyGear remote dampers to the fronts.
The MegaFloat sucks. It simply does not work for light guys like us.
Q. Arrius
Here's my solution:
Q. Arrius
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Any std coil shock from the tunnel adjust mono shock will be a direct fit. You could then use my adjustment tool for adjustments so you don't have to mount the tunnel adjuster. I have some good used shocks here if you decide to go that route.
What's the adjustment tool? How much you want for a shock? I have a buddy here that has front takeoffs from his vector does anyone know if the vector shocks are the same as the apex?
08 and up will fit.
ualav8
Just installed my RA block off kit with adjuster key- slick easy install and as an added bonus- cleans up the tunnel. Thanks Travis!Any std coil shock from the tunnel adjust mono shock will be a direct fit. You could then use my adjustment tool for adjustments so you don't have to mount the tunnel adjuster. I have some good used shocks here if you decide to go that route.
