Do you carry Torco with you?
Here you go...not the best picture but it all fits and works well
BEAST you're killing me!
Luckily, i've been reading your posts long enough to first take a hit off my inhaler then read your post as fast as i can so i can decipher the second time i read it what the HELL is going on.
When i finally meet you, i'm going to to give you a hug then give you a C- for grammar.
You are improving though!
I have run torco,and kept it in my large Yamaha rear tunnel bag,which is large enough to carry 2 gal container of fuel lying down,so I also tapped cap than wrapped with bubble pack,and tapped the bubble pk all togeather,and it worked,but I also have run and brought the small plastic bottles of lucas,along and used with good results. Much cheaper and easier to use,in fact,empty each bottle of lucas per fill up,if filling up more than 5 -7 gal. But what else we can run and does work good to,is Heat,and it is cheap,in plastic containers,and one time only use.
So BEAST let me ask you this. Do you add an additive every fill up over 5 gallons?
Will you knock if you don't?
No have had no knock with max16 and 93 octane. But lucas or heat if needed would work. Thanks for the Hug...lol and C on grandmar...ha ha.
