Also - for the little idler wheels to be effective, you will have to mount them further ahead of the hole you are referring to.
Sevey,
That might the case if one's rail looked like that in the pic WiscSledder1969 posted. My hole is in a different location. If you look at my pic above, the excessive hyfax wear area starts right underneath the empty hole in my rail and peaks about 3 inches/8 cm back. I started with fresh hyfax and that wear depicted is just from 44 miles/71 km of riding in Old Forge, NY last weekend. Conditions were horrible. So why did I even bother? I have limited opportunities to ride due to my work schedule and have to travel 500 miles north to ride and thus will seize an opportunity even if it seems the conditions will be marginal. Conditions were worse than we expected with lots of rain and my buddy and I called it quits after just 44 miles/71 km last Saturday. My sled's temperature warning light kept coming on even with attempts at dipping into the side and hyfax was disappearing right before my eyes. Warm temperatures (45F/7C) didn't help the situation.
My drive back to DC takes me right past Excell Motorsports on NY route 12, so I stopped in and bought the 6 wheel kit on impulse, but haven't installed it yet. I also ordered Over the Top's ski mounted ice scratchers when I got home.
I'm going to replace the hyfax today or tomorrow. On a visual inspection, the hyfax is presently worn well above the bottom edge of the wheels. I'll get a good pic and measurements when I replace the hyfax and post here. So it would seem that once you wear the hyfax a bit, the OEM wheels will be proud of the hyfax which seems similar to the case you end up with oversize wheels with fresh hyfax. Without having taken measurements, the differences seem to be:
1) With oversize wheels, you start with the wheels being proud right off the back. This increases your exposure time to high deflection wheel impacts over the course of a given set of hyfax’s life, thus increasing the likelihood of cracking a rail.
2) With oversize wheels after the hyfax wears substantially, an impact to a wheel can deflect said wheel a greater distance torsionally, when compared to an OEM wheel, before the hyfax shares the impact load. Greater torsion equals greater strain/stress and thus increases the risk of getting the rail to the point of the aluminum’s ultimate stress. A fracture then ensues.
In any event, the question to forum members is still, “Does the Yamaha marginal wheel kit’s bracket bolt hole line up with the existing hole in the arch of 2013 Nytro RTX rail?”
- Walt
