MikeAttakNYC
my friend has an 08 nytro and is curious if anyone makes or has aftermarket bars. He likes the flex bars for atvs does anyone know of a similar bar available for sleds?
BLUEBALLER
- Jan 29, 2005
Re: Handlebars
If he wants the same effect as the flex bars, take a look at isovibe or rox. They both make antivibe risers that will work with the stock handlebars. I've got rox a rox 2" antivibe on mine, works slick.
If he goes with the flex bars - make sure they are 7/8" diameter and they should work with the existing hardware.
APEXgtANDaBANSHEE said:my friend has an 08 nytro and is curious if anyone makes or has aftermarket bars. He likes the flex bars for atvs does anyone know of a similar bar available for sleds?
lucky_7
You can look at the RSI bars, and you can locate them on www.sledsolutions.com.
tomMTX
- Mar 18, 2008
- Bellevue, WA
- www.omlb.com
I just installed a set of RSI tapered Race bars on my 08 Nytro MTX, quality stuff.
NyTrOMaNIaC
How's the heat to those ??? handwarmers, tomMTX ?
snirt
how about the throttle ,looks like it would get pretty tight on a left turn?
tomMTX
- Mar 18, 2008
- Bellevue, WA
- www.omlb.com
NyTrOMaNIaC said:How's the heat to those ??? handwarmers, tomMTX ?
I installed (well with some help from Ruffy) some RSI Hi Power Heater Elements. Still waiting for the snow to put them to the test, but they are really warm in my garage.
lucky_7
How was the install for the grips/heating elements, and also the wiring?
