Threeman03
- Nov 1, 2015
- Flushing,mi
- 2016 Yamaha sr viper ltx LE
Does this look correct ?
IMG_3203.HEIC
IMG_3203.HEIC
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
I don't see a picture
Sent from my iPhone using Tapatalk Pro
Threeman03
- Nov 1, 2015
- Flushing,mi
I can’t get picture to upload.Does this look correct ?
IMG_3203.HEIC
silverram323
- Mar 24, 2013
I sent you a PM
silverram323
- Mar 24, 2013
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Looks sandblasted to me. Normal wear and tear.
Yup and I would move those preload nuts down/tighter a good 3/4in. But that's just my opinion.
Threeman03
- Nov 1, 2015
- Flushing,mi
I ah
i agree totally. What is that like dual spring. I can see how tightening the preload nuts would stiffen little spring but how does that stiffen bigger spring !?Yup and I would move those preload nuts down/tighter a good 3/4in. But that's just my opinion.
It doesn’t much but the big spring comes into action way sooner. Lighter steering and more transfer is effect.I ah
geez150
Shock looks upside-down to me, shouldn't the adjuster be on the bottom?
allyammies
That's what I thought.
fourload
Adjuster is on the bottom on my new sled.
Was on top the LE’s I sawAdjuster is on the bottom on my new sled.
swampcat
Otherwise the QS knob would be on the bottom. Hard to reach, hard enough to reach on the top. That shock does not have the protective sleeve anymore.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
On the dual spring set up leave the preload adjustment on full soft and adjust how the tall spring comes in with collars. If you want the long spring to come into effect sooner, put in a taller collar, or an additional collar, in, effectively bottoming out the short spring sooner. My dual rate springs have adjustable collars so i can adjust without taking the spring off.
